Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Are Scripts affected by current user permissions?
2 REPLIES 2
scottmoyse
404 Views, 2 Replies
In other words, if the currently logged in user doesn't have permissions to see items being referenced in other workspaces by a script, or uses fields in hidden sections. Will the scripts still run as intended?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Tags (1)
2 REPLIES 2
michelle.stone
in reply to: scottmoyse
Scott - I double checked with our scripting guru to verify.
"the script will run..  script permissions are only goverened by the access to the events.  Meaning, if you have access to edit, add item, or perform workflow transitions, these will fire scripts and they will run as you expect."
Hope that helps!
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
Autodesk, Inc.
scottmoyse
in reply to: michelle.stone
perfect thank you
Scott Moyse
