Can anyone explain how the attachment/fileStorageKeyHash is calculated.
Is it on the attached file only? If so, what algorithm is used?
I am hoping that I can compare a file on my local computer with a PLM attachment without having to download the full attachment.
(I don't trust filesize alone).
Sten
Solved by gasevsm. Go to Solution.
Sten,
I hope that Support has reached to you already. Apologies for the tardiness in replying here. This is a reserved variable that isn't PLM-managed and calculated; hence shouldn't be used for comparing local file copy to an uploaded file.
My recommendation is to use a binary compare tools or algorithm that calculates and compares hashcodes between a local and a downloaded file.
