Under a workspace I have nine sections. When I set up an advanced print view and select item details it does not seem to place them in the same order as is in my workspace.
I then remove the item details and started placing the sections individually in the order I need. After running the report I went back into the advanced print view and it seems to of rearranged the sections again. The report or email in this case seems to be printing in the correct order. Has anyone else seen this?
Solved by jpiggee. Go to Solution.
Scott,
Haven’t seen this one before, any chance you could capture it so I can see what’s going on?
Sure thing. I have attached two images. One is of the workspace and the second is the from picking item details from the advanced print view. When it inserts the sections it does not go in the order of the workspace. The workspace shown has nine sections and this makes it difficult to arrange correctly. Thanks.
Scott,
Im going to do some testing on it this week, reproduce it, and see why its happening.
Scott,
Found and confirmed, entering in a bug now. It would appear that anything with more than 2 sections will cause the elements to be randomly placed by section when added in the html editor; however this is only shown to have when adding the “Item details” Widget. You can however correct this action by applying the “Item” widgets individually.
