Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
adsync.exe (Autodesk Sync) consumes all memory.
4 REPLIES 4
1005 Views, 4 Replies
Hi everybody,
I have a problem with my computer, start working with my civil program 2013 and this application called adsync.exe shortly after consumption makes most of my RAM in total is 16 gb and this application consumes 14 GB, which could be a solution other than the uninstall program?
Thnk´s in advance!!!
4 REPLIES 4
JohnCHill
Hi Jorge,
This is the discussion group for Product Lifecycle Management solution (PLM 360).  Here is the link for the ACAD Civil forum.  If you could post the error message you are getting on that board I'm sure a Product Support Specialist can help you.
John
John Hill
Support Specialist
Product Support
Autodesk, Inc.
cto
On my system, Adsync.exe constently consumes 13% of my computers CPU cycles on 8 cores, creates heat, and limits the full CPU capacity for other tasks. (what is it doing?) As much as I use 360 sync I still do not want it on all the time. Isn't there a patch that would allow it to run upon opening AutoCAD and then put it to sleep untill needed again?
Tags (1)
JohnCHill
in reply to: cto
John Hill
Support Specialist
Product Support
Autodesk, Inc.
Terryzin
Hi Jorge,
Thank you for reporting your issue. Please try to update to the latest Autodesk 360 desktop version, probably your problem could be resolved. You can find the update pacakage from http://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-360-desktop-security-upd....
Terry
