Show only
Search instead for
Ability to assign specific gaskets for a defined flanged connection in the model
Routing of piping P3D automatically assigns flanges with bolt sets and gaskets in accordance with the spec. However, we would like the ability to assign a specific gasket to be used for the flange sets.
I believe this is doable. In the spec, you will want to assign a property a value on the flange that matches another value in the gasket row of the spec. You can then modify DefaultConnectorsConfig.xml so the gasket search includes this property in the Filter string.
