ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Recap Photo upload problem today
4 REPLIES 4
tim-p
399 Views, 4 Replies
IS anyone else having the problem to day that when they upload photos for a project the images just hang there? The download bar completes and the thumbnail becomes visible but then the bar empties and stays there and the tick sign does not appear so I can't progress any further!! Has anyone else had this problem?
4 REPLIES 4
laguirre
in reply to: tim-p
I cannot drag my picture. It said, try later because it seems to be a problem.
are you trying only the 'drag and drop' method?  if yes, could you try to navigate to the photos instead of drag and drop? (click to open a folder on your machine?)
do let us know, thanks
tanja
laguirre
in reply to: laguirre
The problema happen when I try to upload my picture for a 3D model generation.
Before a Drag my picture. A picture of "Houston we have a problem" appears
Thanks for the quick respond
Leonardo Aguirre
Mechanical Engineer, MBA
Plant Design Consultant (Tunneling & Infrastructure)
[logotipo_firma_mail_SRK]
SRK Consulting (Chile) S. A.
Av. Vitacura 2939, Piso 5, Las Condes, Santiago, Chile
Tel: +56-2-2489-0800; Fax: +56-2-2489-0801
Email: laguirre@srk.cl
www.srk.cl
This transmission is intended for the sole use of the addressee, and may contain information that by its privileged and confidential nature is exempt from disclosure under applicable law. You are hereby notified that any dissemination, distribution or duplication of this transmission by someone other than the intended recipient or its designated agent is strictly prohibited. If you have received this transmission in error, please notify the sender immediately by replying to this transmission, or by collect call to the above phone number.
P Please consider the environment before printing this e-mail.
ReCap_Ju
in reply to: tim-p
We are having issues with our servers.
This should be solved at this time. If you still experiment the problem, please go directly to:
http://recap360.autodesk.com/signin.aspx
And signin in again.
Sorry.
Rail Community
