Hey guys, I've just started testing doing some photogrammetry using my QR X350 Pro, a GoPro2 (hard mounted) and Autodesk ReCap 360 check out the results here;
Solved by vidanom. Go to Solution.
Nice work
The next level will be going with the GoPro 3 Black editions which we officially support, and trying out āUltraā mode for the best results.
Make sure to check out the final mesh in its full capacity in Project Memento after downloading the obj or rcm file format.
Mitko
Thanks for the tips. Yes I'm looking forward to experimenting and learning more about realisty capture and using ReCap 360. Cheers
