I am asking a photographer is thery would be will ing to catpte a small building that will be historaiclly restoreed. I would like to send her a bullet of do's and don'ts while taking the photos. I can't seam to find anything out there that is not in a video. she is in a remote area and text emails are best, verses videos to watch. Can someone provide a link or a PDF that covers the basics.
Thanks..
here is a photo of the cottage. all the trees and shrubs around have been removed. Also it is a Frank Llyod Wright design. It was called the Monte Carlo because of all the gambleing that took place in the cottage.
http://www.loc.gov/pictures/item/mi0325.photos.035156p/resource/
Yes its true there are mainly video tutorials. But if possible its worth checking as we can see people in action, especially for the acquisition phase ...
I found this pdf tutorial ; check the last chapter (h10.ADDENDUM ‐ How to take photos...)
https://adsk-recap-public.s3.amazonaws.com/Getting_Started_Guide_ReCap_Photo.pdf
I would add the followings, having seen the house:
- keep as much as possible the entire house (or good part of it ) in the image ; like the one shared
- use wide angle lens if possible (<30mm) that does not distort too much
- do not change focal on every shot (its supported but less constrained ...)
- take photos all around from standing positions; carefull on vegetation that might occlude parts
- take also some photos from higher positions if possible : using stick, long tripod or stepladder
Hope it helps,
Stephane
