ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
New Memento update
4 REPLIES 4
TatjanaDzambazova
1015 Views, 4 Replies
New Memento update
Hi all,
We just launched a new update of Memento, our an end-to-end solution for converting any reality capture input (photos, scans) into high quality 3D mesh that can then be cleaned up, fixed, prepared and optimized for further digital use or fabrication.
We now support two workflows:
• Create a new mesh from photos, clean up, fix and optimize for export or 3D print.
• Work on existing mesh made elsewhere and do clean up, fix and optimize for export or 3D print.
Overview video:
http://www.youtube.com/channel/UCfNQX8jp0dGHwEqlWOdd99Q
Getting started guide ( http://autodesk.blogs.com/files/Project%20Memento%20Getting%20Started.pdf)
Memento forum: https://beta.autodesk.com/project/forum/
if you havent yet joined Project Memento, here a link to join: https://beta.autodesk.com/callout/?callid=D69655022B4F42C880513D4E3085C7D0
 after that the link to download Memento will be here:  https://beta.autodesk.com/project/home.html?cap=4BA65236E0B44E33A23FAEB4535DC9E5
Here is the list of improvements:
• First implementation of photo-to-mesh creation from within Memento. The process is fully automated and offers great first integrated experience for creation of mesh from photo. The quality of the photo reconstruction is set to Normal (a level between Preview and Ultra) and is free of charge. Note that this first implementation of creating meshes from photos in Memento is limited in comparison with Photo on PeCap360 (no manual stitch, survey points or distance input yet). But it’s a start!
• .STL import
• In-product connection to the Autodesk 3D print utility, save as .STL, as Objet, or Makerbot Project files.
• In-product live update. Starting with this release there will be an in-product notification whenever we launch a new update. Good timing, as we plan to start updating more frequently!
Please take 15 minutes to read the Getting Started Guide – it takes a lot of effort to write it, but it informs of best practices and answers many questions that come up.
While we consider this still to be a modest preview of our ambitions plans, we hope you will try the toolset and get a sense of where are we going!
4 REPLIES 4
in reply to: TatjanaDzambazova
Memento wont start at all for me! (not even after upgrade).
Direct X wont install at fresh install...
Win 7, language SE(swedish)
Any suggestions?
Error message!
Problemhändelsens namn: APPCRASH
Programnamn: memento.exe
Programversion: 1.0.16.1
Programtidsstämpel: 554c5ac0
Namn på felmodul: KERNELBASE.dll
Modulens version: 6.1.7601.18798
Tidsstämpel för felmodul: 5507b87a
Undantagskod: c06d007e
Undantagsförskjutning: 000000000001aaad
OS-version: 6.1.7601.2.1.0.256.48
Språkvariant-ID: 1053
Ytterligare information 1: 21f1
Ytterligare information 2: 21f1c4c32c7450705a3d1304bb69f57b
Ytterligare information 3: 5875
Ytterligare information 4: 58752c1566dd03c53f62cf5bc1ac3d8d
eugene.chua
Hi!
Would you mind generating a crash dump for us to perform further analysis?
To generate a crash dump you will have to run Memento with administrator privileges ...
  • Right-click on the Autodesk Memento shortcut and select the "Run as administrator" context menu item.
  • Select the "Close the program" option in the "Memento.exe has stopped working" dialog after it crashes.
  • Browse to the folder where Memento is installed (for example "C:\Program Files\Autodesk\Autodesk Memento\")
  • Look for the crash dump file(s) that will have ".dmp" extension (memento.dmp and memento.Qt.dmp)
  • You may upload them by emailing them to upload.Crash_D.m4w57avhc4@u.box.com
You may also want to try clearing Memento's A360 project cache ...
  • Navigate to and delete the "%localappdata%\Autodesk\Autodesk Memento" folder.
  • For example, "C:\Users\eugene\AppData\Local\Autodesk\Autodesk Memento".
-Eugene
in reply to: eugene.chua
Sorry,
Got it to work. It was the compability problem... did run the setup file as Administrator and in compability mode "Win XP". Solved the problem! 🙂
eugene.chua
No worries! Thanks for sharing. 😃
Rail Community
