Is there a way to force Recap360 to only output one ID so you will only get all the UV's on a single texture in the OBJ format?
This would massively help cut down work I'm doing in my pipeline - if not could this be a feature request?
thanks for your help!
It’s a feature request,
Thank you for reporting and we would love to hear more;
Anything that would improve your workflow, why and what are the projects you are working on.
Fill free to send us any input in a private message.
Best,
Mitko
I found that if I use a bounding box or autocrop, I only get one UV map.
With the crop tool you are reducing the unnecessary area for the UV map, but if you are uploading many photos with high pixels, you should still get multiple textures.
Also the sharper the photos the more pixels will be matched, resulting in more accurate dense models and more high detailed UV maps.
Mitko
This has been my number one request going back to the 123d Catch days. The multiple material ID and maps works fine as long as the target application supports it (3ds Max) but it is incompatible other programs like Zbrush. This requires an extra step of baking out the textures into a new UV channel and single map before working in those programs, which takes extra time and reduces texture quality due to the necessary resampling caused by baking. Not to mention the process might be too complicated for some users to even understand, or the fact they don't have access to the right sotware to bake in the first place.
There really should be an option to FORCE the texture into a single material ID and bitmap. That being said, if the user wants the multi material and map results (leaves this option on), I suggest Recap produce such UVs and textures using the UDIM approach and NOT via overalpping UVs that share the same coordinate space.
