Maybe add a "make base" option, I need to print some of the models on a z650 printer, would be great to be able to output in one go and have a closed solid. 😉
Bo
Solved by vidanom. Go to Solution.
Thanks Bo,
If it's 30 frames per sec. I would say good enough is 1 frame on every 300 frames. Try keep the EXIF data when extracting the frames.
However, instead of videos we strongly recommend taking photos. In videos there can be a lot of pixels drifted in the wrong location, which can result in weak results from the service.
You can set up the camera on 5sec time-lapse.
Best,
Mitko
I could not agree more, even if video might seem easier because of the continous motion, it suffers from several potential issues:
- video frames will lack of EXIF information
- the process will have to deal with some motion artifacts: motion blur, rolling shutter effect (due to CMOs sensors on most small devices, ...)
- the resolution will be much lower than with still images
Nico
