Hi Recap Devs,
I am trying to use Memento to export a Recap model to an OBJ so I can fix it up with mesh mixer but for some reason the textures aren't importing in. If I try to use Meshlab it complains that the material file has an issue. I have never had a problem exporting from Memento before. Has anything changed recently with how models are saved in Recap?
Matt
Solved by Pierdi. Go to Solution.
Hi Matt,
From what I understand the exported files from Recap looks OK (RCM and/or OBJ).
The problem appears when you try to export an OBJ from Memento, this new OBJ seems to be corrupted when you open it in another software like Meshmixer or Meshlab, right ?
Don't know what version you are using but perhaps there is a limitation due to texture size.
If your JPG textures are generated in 8K, can you try to reduce them by 2 or 4 (test with 4096 or 2048) and see if they are displayed in Meshlab ?
Are you open the OBJ file from a network path ? If so, that would impact on the fact he can't find the *.mtl texture library.
If not, just forget that hypothesis 😉
Pierre
OK the problem comes from the fact you have some spaces in the name of your scene.
If you resubmit your scene with a name like "copy_of_MomNME1" it would works fine everytime.
If you prefer to keep that scene, here is the workaround to see it in another 3D software:
1) Change the Copy of MomNMe1 scene name by MomNMe1 for example.
2) Now change the extension name of MomNMe1.obj to see MomNMe1.txt
2) Open MomNMe1.txt with a text editor
3) Change the name of the mtllib name and put "MomNMe1.mtl" (see attached screenshot below)
4) Save MomNMe1.txt then rename it MomNMe1.obj
5) Change the file name "Copy of MomNMe1.mtl" by "MomNMe1.mtl"
6) Open it Meshlab 🙂
Hope it helps,
Pierre
