I have used 123D Catch successfully for over a year. Having extremely difficult time of trying to accomplish same in RECAP 360. I have several photo scan drafts. Don't know where to go/what to do next.
If you want to be able to:
You should consider to get a subscription.
Then if you want to improve your result, you access the online viewer by clicking on your project tile on the home page.
Once opened you have several options here:
If you are familiar with 123DCatch you will be able to achieve the same here.
Hope this helps, otherwise I missunderstood your problem 🙂
Regards
Hi Sanderto,
to be sure we cover all aspects of your question, given that i understood it a bit differently than my colleague:
if you were confused how to start a project on the recap360 site, go here https://recap360.autodesk.com click on New Photo Project (if you dont see that on the first screen, you might be in 'scan' not 'photo' mode, in that case switch to photo mode using the green icon with the photos on it, on the right side of the screen.. Than a dialog appears, pick a name for the project, type of reconstruction etc and upload photos. When the project is done you will receive an email with a link to the created mesh.
you can also try Project Memento that is on Autodesk Labs, follow this link: https://beta.autodesk.com/callout/?callid=D69655022B4F42C880513D4E3085C7D0 ,
where you can also create photo to mesh reconstructions but also have tools to clean up the mesh, fix , edit and export or full 3d printing functionality. What you will not have in the current build of Memento are manual stitch tools, adding survey points and distance, as we have not yet implemented them.
please let us know what works for you and if any of our answers were helpful
and curious, (if you are willing to share) - what type of objects are you capturing? small objects? buildings? else?
many thanks!
tanja
