ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Blank screen when I open my project
13 REPLIES 13
Message 1 of 14
devitt
2398 Views, 13 Replies
I've been testing ReCap360 and I've had several successful projects. But my latest project just goes to a blank screen when I open it.
I got an email saying that it was successfully processed, but when I open it from my gallery I see a gray blank screen. The 'proxy mesh' warning appears at the top of the screen and goes away after a while. But the rest of the UI is blank too - not even a link back to the home page.
JD
13 REPLIES 13
Message 2 of 14
Pierdi
in reply to: devitt
Hi Devitt,
Thanks for your report.
What web browser are you using ?
Is the problem appears on that project only or did you ever experienced this behavior with an other scene ?
Could you share your project with us, if possible ?
That would help a lot to understand why you don't see your scene in the 3D viewer.
Click on the sharing icon and enter the following address:
recap360@autodesk.com
Pierre
Message 3 of 14
devitt
in reply to: Pierdi
I'm using the latest version of Chrome and can open other projects without a problem.
I have shared the project with recap360@autodesk.com.
Message 4 of 14
Pierdi
in reply to: devitt
Hi Devitt,
Thanks for the sharing, we have found a problem with your scene but it should be fixed now.
Could you try to open it again ?
Pierre
Message 5 of 14
I am having the same issue. Except my problem is that all projects on 1 computer (windows 7 x64 w/ chrome) show the grey screen only, and all projects on another computer (windows 7 x64 w/ chrome) show them all fine. Also they show fine on the mobile app.
Any ideas?
Message 6 of 14
Can you try to clear your cache on Chrome and see if it's better ?
On Chrome, go on Settings > Show advanced settings...> Clear browsing data button
Select Cookies and other site and plug-in data only if you want to keep your other data, then clear it 😉
Once cleared, you need to close Chrome then re-open it.
Hope it helps,
Pierre
Message 7 of 14
Done that. Uninstalled, reinstalled. Goes to the grey screen with the circles spinning and then that goes away and it is just a grey screen.. the horizontal dots never show up or any image or controls. I can click HOME but that is it.
Message 8 of 14
Could you make some tests and check if your equipment support the WebGL display format ?
First, I would suggest you to click on link hereafter and check if you see a cube:
http://get.webgl.org/
If you don't see the cube, perhaps it come from a problem with your grahic card. Could you update the graphic drivers and see if it's better ?
If you see the cube, let's double-check to see if your browser can open another 3D element which use a similar viewing technology, please click on the link below:
https://fusion360.autodesk.com/models/5ea1163b77b3f3733984c98698292736/embed
In a second time we would be interested to know what the Chrome console says when you open the Recap360 scene.
In Chrome, press F12 to show the Console then open your scene in the Recap360 viewer.
During the opening process, do you see an error message (in red) ? If any, can you paste it or make a screenshot of it ?
Pierre
Message 9 of 14
bdnewnan
in reply to: Pierdi
Failed to load resource: the server responded with a status of 500 (Internal Server Error)
Message 10 of 14
bdnewnan
in reply to: bdnewnan
Host name : recap360.autodesk.com globalinit.js:146
Environment initialized as : Production globalinit.js:147
THREE.WebGLRenderer 66 FireflyWebGLRenderer.js:12
GET https://recap360.autodesk.com/firefly.js/icons/turntable_cur.cur 500 (Internal Server Error) ProgressBar.js:14
Extracted URN: urn:adsk.viewing:fs.file:dXJuOmFkc2subml0cm9nZW46ZnMuZmlsZTpiYTMxOWM3ZjNlMTQ0NjBkYWVkZjFiOTNhMTBhNWUyZg== globalinit.js:275
GET https://recap360.autodesk.com/firefly.js/src/zlib/gunzip.min.js.map 500 (Internal Server Error) /firefly.js/src/zlib/gunzip.min.js.map:1
GET https://recap360.autodesk.com/firefly.js/src/zlib/unzip.min.js.map 500 (Internal Server Error) /firefly.js/src/zlib/unzip.min.js.map:1
Setting 'XMLHttpRequest.withCredentials' for synchronous requests is deprecated.
SVF load: 3387 globalinit.js:275
scene bounds: {"min":{"x":-7.388325,"y":-6.641986,"z":4.127608},"max":{"x":8.544771,"y":6.912096,"z":31.6852}} globalinit.js:275
Fragments load time: 2856 globalinit.js:275
Total geometry size: 2.6982955932617188 MB globalinit.js:275
Number of meshes: 7 globalinit.js:275
Num Meshes on GPU: 7 globalinit.js:275
Net GPU geom memory used: 2829368
above is my error messages, this for a file that was created Oct 30, finally opened.  More recent files fail to open.  Help
Message 11 of 14
bdnewnan
The key "target-densitydpi" is not supported. viewer3d.html:6
Failed to load resource: the server responded with a status of 500 (Internal Server Error) https://recap360.autodesk.com/firefly.js/icons/turntable_cur.cur
Both viewer tests were ok.
Message 12 of 14
ideerge
Are you experiencing this in all your created projects?
We had an outage yesterday, so if you experienced it for the last two days, can you please try a resubmission ?
Darren
Message 13 of 14
ideerge
None of the errors you wrote here cause any disruption in loading your model in the viewer. you can disable js map in your chrome browser setting to remove those errors too if you want
Message 14 of 14
TalonOne
in reply to: ideerge
I can't open any of my models in Chrome either.  I can open ones from a few days ago but stuff from yesterday/today I can't open in the web viewer.
I've been downloading the obj file and using meshlab as a work around.
 Matt
Rail Community
