would like to create an object that reacts to the water surface. lets say a rubber duck that moves with the water up and down. can anyone point me in the good direction for 3ds max?
thx
I would do the following:
-Create a point helper
-Go to the Motion Panel > Assign Controller > Select "Position" >
-Click on the "Assign Controller" button and choose "Attachment"
-In the Attachment Parameters set your water as the object and then click on "Set Position"
-Click and drag on the water to reposition the helper along the surface of the object
-Click on the same button to deactivate when done
If you simluate/play your animation you should see the helper locked to that point on the water surface
Last step would be to parent the object that will appear, the rubber duck in this case, to the helper so that the duck will animate with the helper
The point of the helper is to allow you do animate the duck slightly differently if needed, to show weight for example.
