Hi
I have a bunch of particles falling. I'm using a dummy to offset the pivot of the ShapeInstance reference object and applying a spin so they follow a spiral path downwards. I'd like them to spawn a trail, but the spawned particles follow the pivot points, not the child meshes.
How can I have the spawned particles also follow a spiral path?
Mark
Solved by BenBisares. Go to Solution.
I created a set of videos that will show you my suggestion on how to create the particle trail effect you would like.
The one thing you will need is to download a script that will bake your particle animation into a regular keyframe animation. You can find it here:
http://www.scriptspot.com/3ds-max/scripts/pflow-baker
Here are the links to the videos:
Video01: http://www.screencast.com/t/UJUYv0ZP
Video02: http://www.screencast.com/t/SqSY14OM90
Video03: http://www.screencast.com/t/3dXFofgyLC
Take a look at them and tell me if this answers your questions.
