3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
particles falling on moving surface and continue moving
1 REPLY 1
imranovi
372 Views, 1 Reply
Hi
am creating a moving water surface and leaves are falling on the surface, the leaves are particles,
 am using lock/bond to make  them stick to the surface and keep moving with it, but
can I make them keep moving with the stream direction??
help please
Tags (2)
1 REPLY 1
ollyV
in reply to: imranovi
If you reduce the lock bond force to less, maybe 80 or 90%, and then add a force or something to move the leaves, that should work.
It will be a balance between the force of the lock/bond - how much it locks' and whatever method you use to move the leaves in the water.
