I am sorry for answering a post where it doesn't belong. I need some help quickly on a particle flow and really don't know where to turn and how to find the right forum to post this. Please help. I'm on 3ds Max Entertainment creatin suite 2014 and have a PFlow question. Pleas direct me to the correct forum so I can post a question to solve my problem. Thank you so much if you decide to help me. Or at least send me in the right direction. I need someones help on duplicating a particle flow. Thank you. Thank you.
I'm new to this forum but I should have been on it for years. Sorry. I have a specific question. I have a particle flow setup. The scene shows a pipeline and a valve. The gas pressure pushes rust and debris down the pipeline that collides with a ball on a large ball valve. I have the PF setup and you can see the particles blow into the frame and bounces off the ball as it is closed and the particles come to rest at the bottom of the pipe. Now I copy the three pflow events and then suddenly the deflectors pass completely different information on to the next event. I can't figure out why. It must be something simple that I'm missing. I can post a sample if someone can help me. Please. Thanks in advance.
