The short answer is, yes, max can do all that (except convert the output to a flash movie, you'll need a utility for that - flash for example - but it's a small step).
The longer answer is that if you want to do everything in max, you're looking at a long learning curve. One thing to look at is to continue to create your models in sketchUp (i have friends, designers mostly, who swear by it), and possibly the landscapes too, and then import it into max. This way you're using tools you're already familiar with for the modeling and can use max for the fly through animation which is relatively easy to do. |
Thanks for your input.
Yes, I fully understand the learning curve is much steeper than SU. I do however like to learn and this software seems very intriguing to me, and spending some time learning this, if it can be utilized in my business, would be worth while the time for me.
It is however interesting that I can import my SU models into 3dmax and use them there. Will this be obj files?
It is the smooth movie effect that is important to me.
Tom
