Thanks, now worked it out. Part of my problem was that I have only one
reactor for several objects (1,2,3 all have same reactor).
Figured that this would make things easier: reactors contain only method not
data, data is hold within my custom objects.
Object A knows from where notification event started because, say 2, sets
flag to A. Problem solved......for now.
Andrus
"Matt" wrote in message
news:5107186@discussion.autodesk.com...
Try Adesk::Boolean isNotifying() const;
Check it in the beginning of you reactor-function, and return if so
I recall this from and old class i went to, but not sure if it shoud be
called on "this" or on the argument
/Matt
"andy" wrote in message
news:5106135@discussion.autodesk.com...
I'm with problem with persistent reactors & stuff here. I have an object A.
Then I have objects 1, 2, 3.
If user changes A then A opens 1, modifies 1 then 2 and then 3. If user
modifies any of 1, 2, 3 then
problems begin. If 2 gets changed, then it calls A, but A will now want to
modify all 1,2,3. It will take 1 and crash..
So A should now what caused its modified() called. If user changed A it
should modify 1, 2, 3.
If object 3 called A then A should try to modify only 3 to prevent infinite
loops.
Please help me out here...
Andrus
