Removing XDATA isn't going to solve the problem of
custom dependencies in the file. XDATA is generic
and doesn't create dependencies on any library.
Custom objects and 'hard' references to them can
exist in the extension dictionary of any object, as well
as in the root/named objects dictionary.
If you want to post an otherwise-empty file that has
the dependencies in it, I'll have a look at it.
Best Regards,
Tony Tanzillo
Design Automation Consulting
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6124650@discussion.autodesk.com...
Thanks Tony, yeah If I have to do future shared work, that's a great idea
(wish I had done that to start with). What I am really looking for has more
to due with where stuff is stored that triggers the load (AutoCAD preserves
any Proxy Objects in the database regardless of what libraries are loaded at
Save- right?). I'm trying to clean up the drawings after the non-graphical
entities are already in them. I have gone in with LISP and tried deleting
Dictionary Objects after identifying the standard AutoCAD dictionary
entries, but I didn't quite work. I don't know if I missed one, or if the
info is stored in other places as well. I have used the "Export to AutoCAD"
function available, but it has had some side affects (purging stuff I didn't
want to lose, etc). Is there Xdata attached to AutoCAD non-graphical
entities or some other less obvious place where the info is stored? I was
theorizing that if I could identify the App through the Regapp list, then
start scanning all the entities for Xdata associated with that app, and
remove it when it's found and purge the Regapp table. Am I on the right
track? Thanks, tom
