ObjectARX
WblockCloneObjects() returns eNotAllowedForThisProxy
1 REPLY 1
chunyuran
1243 Views, 1 Reply
WblockCloneObjects()  returns eNotAllowedForThisProxy.
Anybody know how to handle this? Thanks advance.
1 REPLY 1
If the drawing contains proxy-object/entity that was created without the flag kCloningAllowed, when you try to call the method for them WblockCloneObjects () is an error code eNotAllowedForThisProxy returned. IMHO there are two alternative solutions:
1. Set Object Enabler for this Custom Object / Entity
2. Remove the proxy objects and explode the proxy entities
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
