I have installed ObjectARX2015 and VS2012 with update 4 and recompiled my app.
I have the following Warning:
"rxapi.lib(nullobid.obj) : warning LNK4254: section 'rxapi' (C0000040) merged into '.rdata' (40000040) with different attributes"
All was OK with ObjectARX2013 and VS2010.
Is there anyone having a solution to this problem ?
Thanks in advance.
Patrice
Solved by patr93. Go to Solution.
Hi Patrice,
I had seen a similar warning while migrating one of the samples and had forwarded a similar query to our engineering team.
The feedback that I received from our engineering team is :
This warning can be safely ignored.
The code that causes this warning is an optimization for creating a global variable and there has not been any change around it in the AutoCAD 2015 release. I suppose the change in the C++ compiler used with AutoCAD 2015 is flagging it as a warning while the previous compiler versions ignored it.
Balaji
