ObjectARX
ObjectARX
Active Member
zero111
Message 1 of 5 (176 Views)
Wait for a command , Acad sometimes show a rotate line in command line
176 Views, 4 Replies
06-13-2012 12:20 AM
I want get the APII for rotating a short line in command line
Active Contributor
cadproman
Message 2 of 5 (166 Views)
Re: Wait for a command , Acad sometimes show a rotate line in command line
06-13-2012 07:01 AM in reply to: zero111
Active Member
zero111
Message 3 of 5 (165 Views)
06-13-2012 07:24 AM in reply to: zero111
not StatusBarProgress, it shows in command line like rotating a short line.
Valued Contributor
Patch61
Message 4 of 5 (136 Views)
07-26-2012 08:29 AM in reply to: zero111
I believe this is done by continually overwriting the prompt line with the ascii characters - \ | /  (hyphen, backslash, bar, front slash, then repeat).
I don't think there is a way to do this through the api.
Every so often, your program will need to send a backspace character and the next ascii character (given above) to the command prompt. This will make it look like a spinning line.
The backspace character will erase the previous character, then the next character is shown. Then a slight pause, then another backspace and the next character.
Let us know how it works out.
-Patch
(edited for spelling)
drobison
Message 5 of 5 (106 Views)
08-30-2012 10:31 AM in reply to: zero111
If you do a (princ "\r"), it will overwrite the current line of text, rather than making a new line.
Using that and manually incrementing the line you are rotating, you can get a spinner at the command line.
You migth need to throw another (princ) in to get the command line to update. In Lisp, it looks something like this:
(princ (strcat "\rMessage" spinner))
(princ)
