ObjectARX
VIEWBASE with ObjectArx
4 REPLIES 4
marioriva
519 Views, 4 Replies
Good Morning,
with Autocad 2013 is it possible through ObjectArx API to use VIEWBASE and similar commands?
Mario
4 REPLIES 4
owenwengerd
in reply to: marioriva
Yes, it is possible from certain contexts.
Owen Wengerd
ManuSoft
marioriva
Do you know where can I find an example or guideline? and what does it mean exactly "from certain contexts" ?
I want to use the viewbase command and similar to automatically create new layout for each piece (3dsolid) or selection in the model.
Each layout contains base view, front, top view, etc. and annotation.
Thank you. Regards,
Mario
owenwengerd
See here for more information and sample code executing AutoCAD commands:
http://through-the-interface.typepad.com/through_the_interface/2006/08/techniques_for_.html
From your description of the goal, I think you may want to use a different approach that does not involve calling commands, but instead creating your layouts programmatically. I don't have any links to examples.
Owen Wengerd
ManuSoft
m_othman2001
Hello Mario,
I'd like to ask if you found a solution to this question as I have the same situation as you described here.
Also if anybody has an experience with such issue, please help.
Thanks and best regards,
Mahmoud
Tags (1)
”Boost
