ObjectARX
vector class
3 REPLIES 3
176 Views, 3 Replies
vector class
Hi there,
we want to use the vector class (dynamical array) in an arx program.
Everything is all right when I build the project. I can run the arx on my
pc, but not on another one. Gives an an error message that there is a .dll
file missing?
Anyone knows what's wrong?
Greetz,
Giuliano
3 REPLIES 3
Giuliano Lodts wrote:
> Hi there,
> file missing?
What .dll is not being found?
| Byron Blattel
| CADwerx---Applications for AutoCAD
| Autodesk Registered Developer
| email: byron@cadwerx.net
| web site: http://www.cadwerx.net
Check out your ARX's dependencies using depends.exe on the user's machine. I
expect you forgot to install a required DLL, or its not in the system search
path.
(Depends.exe is shipped with Visual Studio).
Cheers,
Stephen Preston
Developer Technical Services
http://adn.autodesk.com
"Giuliano Lodts" wrote in message
news:F6FCBA0F6B8754848B8BD869885891CC@in.WebX.maYIadrTaRb...
> Hi there,
> file missing?
> Greetz,
> Giuliano
Giuliano,
Pay attention also if you are deploying the Debug version of your
application which will require the debug version of some MFC DLLs and other
related stuff. If you try to run, for instance, a ObjectARX MFC application
compiled in Debug mode it will miss some Debug DLLs that will only exist on
target machine if there is a Visual C++ installed. Please don't use the
dirty solution to ship Debug DLLs versions.
As Stephen told you, the best solution is to run Depends tool on target
machine and find out what is missing.
A good install application like InstallShield could do this job for you
without need to go physically on the target site.
Fernando.
"Stephen Preston" wrote in message
news:5E9E62363A12B8CD61978D361C877894@in.WebX.maYIadrTaRb...
I
search
> path.
> Cheers,
> Stephen Preston
> Autodesk
> > Hi there,
my
.dll
> > file missing?
> > Greetz,
> > Giuliano
”Boost
