Larry;
Yes I tested your code and was getting the same results, is strange that you
could not use smart pointers, but no problem, here is your routine using
normal calls... HTH.
int GetBlockObjectCount(const CString& name)
AcDbBlockTable* pBlockTab = NULL;
AcDbDatabase* pCurDB = acDocManager->curDocument()->database();
pCurDB->getBlockTable(pBlockTab, AcDb::kForRead);
AcDbBlockTableRecord* pTabRec = NULL;
if(pBlockTab->getAt(name, pTabRec, AcDb::kForRead) != Acad::eOk)
pBlockTab->close();
return -1;
pBlockTab->close();
AcDbObjectIdArray idArray;
pTabRec->getBlockReferenceIds(idArray);
pTabRec->close();
if(idArray.length() == 0)
return -1;
int cnt = 0;
for(int index = 0; index < idArray.length(); index++)
AcDbObjectId id = idArray.at(index);
AcDbBlockReference *pRef = NULL;
AcDbBlockTableRecord *pBtr = NULL;
if ((acdbOpenObject(pRef, id, AcDb::kForRead) == Acad::eOk) &&
(acdbOpenObject(pBtr, pRef->blockId(), AcDb::kForRead) == Acad::eOk) &&
pBtr->isLayout())
cnt++;
pRef->close();
pBtr->close();
//if (pBlockRef == Acad::eOk && pBlockRef->isLayout())
// cnt++;
////if(pBlockRef->isErased() == Adesk::kTrue)
//// pBlockRef->close();
//// continue;
//AcDbObjectPointer
pRef(idArray[index],
AcDb::kForRead);
//if (pRef.openStatus() == Acad::eOk)
// AcDbBlockTableRecordPointer pBtr(pRef->blockId(), AcDb::kForRead);
// if (pBtr.openStatus() == Acad::eOk && pBtr->isLayout())
// cnt++;
// Do some stuff with the block reference here.
////pBlockRef->close();
return cnt; //idArray.length();
