ObjectARX
Transparency not working in 64 bit
5 REPLIES 5
786 Views, 5 Replies
The following code is an example of how I am calling transparency on a custom entity.
For some reason it works in 32 bit but not in 64 bit autocad.
Any ideas?
double setTransAlpha = 40;
AcCmTransparency trans(setTransAlpha);
trans.setMethod(AcCmTransparency::transparencyMethod::kByAlpha);
if(transparency == 0)
       setTransAlpha = 255;
else
setTransAlpha = 255 - ((255.0/100.0) * transparency);
trans.setAlpha(setTransAlpha);
mode->subEntityTraits().setTransparency(trans);
Tags (2)
5 REPLIES 5
Alexander.Rivilis
What version of AutoCAD and ObjectARX are you using?
Facebook | Twitter | LinkedIn
Expert Elite Member
owenwengerd
You'll need to provide more information than "it doesn't work". Does AutoCAD crash? If so, what is the exception?
Owen Wengerd
ManuSoft
I am using AutoCAD 2013 and ObjectArx 2013.
Not working means it's not working. In 32 bit the custom object is transparent. In 64 bit it isn't. No crash, no exception, no error messages. It carrys on as normal except the entity is not transparent.
The code is exactly the same.
ow
And the system variable TRANSPARENCYDISPLAY is set to 1?
in reply to: ow
That was it, so simple, thanks!
”Boost
