ObjectARX
The objectARX wizard will not work in VS 2010
2 REPLIES 2
kennethmjones
1416 Views, 2 Replies
I have installed the objectARX wizard into VS2010 but it will not create a project.
It shows me the attached error dialog and will not create any more files for the project I have attached a snippet of the Autodesk.arx-2013.props to which the dialog refers.
It appears that there is a strange character in the first character of the file which is causing the wizard to stop going any further. It alos appears that the file encoding has changes to anis instead of UTF-8.
I have used all the wizards since the 2011 one and not seen this issue before.
My OS is Windows 7 Home Premium (Japanese language). I have used previous wizards on Vista (Japanese) and did not see this problem.
Has anyone seen anything like this? Does anyone know how it can be fixed?
Any ideas would be gratefully recieved
Anyone from Autodesk out there please help :-(.
Many thanks
Ken
2 REPLIES 2
hss382h
in reply to: kennethmjones
hello
Template file is bug.
"\Program Files\Autodesk\ObjectARX 2013 Wizards\ArxAppWiz\Templates\1033\Autodesk.arx-2013.props"
1line
 ソ<?xml version="1.0" encoding="utf-8"?>
kennethmjones
in reply to: hss382h
Thank you for pointing that out. I found that problem in one of the files but I did not know there was that other one too.
Thank you for your help, very much appreciated.
”Boost
