ObjectARX
ObjectARX
New Member
axelgenus
Message 1 of 2 (563 Views)
Syncronizing attribute references with ObjectARX
563 Views, 1 Replies
01-17-2012 09:09 AM
Hi guys,
I wrote a C# program with ObjectARX which modifies some attribute definition inside two static blocks (height and position). How can I now sync the block/attribute references according to the new definitions (as issuing "ATTSYNC N *") ?
I tried using SendStringToExecute but it's an async method: the program saves and closes the document before the command could be completed.
Thank you,
Alessandro.
ADN Support Specialist
philippe.leefsma
Message 2 of 2 (535 Views)
Re: Syncronizing attribute references with ObjectARX
01-31-2012 02:49 AM in reply to: axelgenus
Hi Alessandro,
Unfortunately there is no direct method do repeat ATTSYNC command. To achieve the same result, you can try the following steps: (1) open the block definition and block reference, (2) iterate though attribute references on block reference and find the appropriate attribute definition (using TAG as a search criteria), (3) use the setAttributeFromBlock to copy the new attribute.
Another option is to send ATTSYNC command:
[CommandMethod("AttsyncCmd")]
static public void AttsyncCmd()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    string bName = "blk1";
    string command = "_ATTSYNC Name " + bName + "\n";
    doc.SendStringToExecute(command, true, false, false);
If you are doing that inside a save & close operation, then yes it will not work. You need to P/Invoke a synchronous method such as "acedCommand". Here is an example:
[DllImport("acad.exe", CharSet = CharSet.Unicode, CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedCommand")]
private static extern int acedCommand(int type, __arglist);
[CommandMethod("acedCommand3")]
public void acedCommand3()
    double rad = 2.5;
    double[] center = new double[3] { 0, 0, 0 };
    acedCommand(5005, __arglist("_.CIRCLE", 5009, center, 5001, rad, 5000));
Note for next time: you may want to post C#/VB.Net questions to the .Net section rather than ObjectARX (reserved for C++).
Philippe.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
Philippe Leefsma
Autodesk Developer Network
Post to the Community
New Post
Need installation help?
