ObjectARX
subWorldDraw Question....
3 REPLIES 3
803 Views, 3 Replies
I'm trying to get some color into my world draw 🙂
This is a custom derived AcDbPolyline object.
I'm working with this for simplicity:
Adesk::BooleanBCHF_LotObject::subWorldDraw(AcGiWorldDraw*mode){
assertReadEnabled();
AcDbPolyline::subWorldDraw(mode);
TCHARbuffer[255];
_stprintf(buffer,_T("\nLOT: %d"),m_LotNo);
mode->subEntityTraits().setColor(2);
mode->geometry().text(m_TxtMspace,normal(),vec.kXAxis,m_TxtSizeMspace,1.0,0.0,buffer);
return(AcDbPolyline::subWorldDraw(mode));
Now, when I set subentity traits to 2 here:
the polyline AND the text turns yellow. I really would like them different...so the polyline is say 1 and text 2 (just an example) or I could even pin them to layers, etc. perfect would be everything is set to a color except the polyline itself, which reacts to layer....
any ideas? short of deriving an entity and remaking polylines from scratch?
3 REPLIES 3
owenwengerd
What happens if you remove the second call to AcDbPolyline::subWorldDraw()?
Owen Wengerd
ManuSoft
in reply to: owenwengerd
*desperately tries to see second call...*
do you mean the return call here:
otherwise there is only one:
though I admit I haven't tried removing the return. the inital DBX wizard put it in there and I left it...
suffering sucotash!
Great advice my friend!
for those (like me) that didnt' just try this in the firstplace cause it's a return,
return true;
works fine, and puts my base poly on layer and rest on forced behavior..
Excellent....
”Boost
