ObjectARX
subGetOsnapPoints override
4 REPLIES 4
igorg1234
791 Views, 4 Replies
Does someone faced the limitation when overriding the subGetOsnapPoints.
The  subGetOsnapPoints is not fire-up at all on my custom entity.
I have attached the solution. I am missing something.
I use ACad 2012 on WIN7 x64.
The same example is working properly on XP(x32).
Thanks for any suggestion.
4 REPLIES 4
Acad::ErrorStatus AuPolyline::subGetOsnapPoints (
    AcDb::OsnapMode osnapMode,
    /* int */ Adesk::GsMarker gsSelectionMark, // Not 'int' but 'Adesk::GsMarker'
    const AcGePoint3d &pickPoint,
    const AcGePoint3d &lastPoint,
    const AcGeMatrix3d &viewXform,
    AcGePoint3dArray &snapPoints,
    AcDbIntArray &geomIds) const;
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Many thanks,
By the way the  declatation for "subGetOsnapPoints" has been  got from ARX Wizard 2012.
So, this should be a message for other users that they should allways check the original heather file for the aguments.
It is possible to change once two files used by ObjectARX Wizard 2012:
"C:\Program Files\Autodesk\ObjectARX Wizards for AutoCAD 2012\ArxWizCustomObject\Templates\1033\object.cpp"
"C:\Program Files\Autodesk\ObjectARX Wizards for AutoCAD 2012\ArxWizCustomObject\Templates\1033\object.h"
Expert Elite Member
”Boost
