ObjectARX
set off a layer
9 REPLIES 9
Message 1 of 10
leonimas
435 Views, 9 Replies
set off a layer
Hi to all,
I want to set off a layer; I've writted the following code (autocad 2012):
err = pLayerTable->getAt(_T("TEXT_DESCR"), layerId);
if(err != Acad::eOk)
    MessageBox(acadHandle, acadErrorStatusText(err), _T("Titolo"), MB_ICONERROR);
    return;
acdbOpenObject(pLayerTableRecord, layerId, AcDb::kForWrite);
pLayerTableRecord->setIsOff(Adesk::kTrue);
pLayerTableRecord->close();
pLayerTable->close();
but the "bulb lamp" icon of the TEXT_DESCR layer, keeps the same yellow state ...
How to simulate (with objectarx) the _LAYOFF command ?
Best Regards
Leonard
9 REPLIES 9
Message 2 of 10
owenwengerd
in reply to: leonimas
Your thread title is misleading, as your question is actually about how to trigger an update of the UI to reflect your programmatic changes. I don't know the answer offhand, but fixing your title may attract more attention. BTW, your code snippet fails to close the layer table in the err != Acad::eOk case.
Owen Wengerd
ManuSoft
Message 3 of 10
leonimas
in reply to: owenwengerd
Sorry,
I expressed myself badly ... the title it's ok, I want to disappear a graphic
entity of a block, and this entity is drawn with the layer "TEXT_DESCR".
If I use the 'setIsOff()' function the entity doesn't disappear ...
Leonard
Message 4 of 10
owenwengerd
Try ads_regen() to update the display.
Owen Wengerd
ManuSoft
Message 5 of 10
leonimas
I've tried acedUpdateDisplay() but nothing ...
ads_regen() where is ? VS2010 doesn't find this function ...
Message 6 of 10
owenwengerd
Here is the declaration:
void ads_regen(void);
Owen Wengerd
ManuSoft
Message 7 of 10
leonimas
ads_regen() doesn't works ... 😞
Message 8 of 10
owenwengerd
In what context is your code executing? Test it in a standard command function to determine whether context affects your results.
Owen Wengerd
ManuSoft
Message 9 of 10
leonimas
the code is the following (inside an  autocad command):
static void ASTSIced_ICEDInsert () {
            err = pDwgDb->getLayerTable(pLayerTable, AcDb::kForRead);
                MessageBox(acadHandle, acadErrorStatusText(err), _T("Title"), MB_ICONERROR);
                return;
            if (pLayerTable->has(_T("TEXT_DESCR")))
                    return;
                //acedUpdateDisplay();
                //ads_regen();
ACED_ARXCOMMAND_ENTRY_AUTO(CIcedApp, ASTSIced, _ICEDInsert, ICEDInsert, ACRX_CMD_MODAL, NULL);
Best Regards
Leonard
Message 10 of 10
owenwengerd
Some things to try:
1) Does a manual _REGEN at the command prompt (after running your command) update the display as you expect? If not, then maybe the problem is your expectations instead of the code.
2) If you are targeting a specific block, perhaps opening all block references of that block and calling recordGraphicsModified() will trigger an update.
Owen Wengerd
ManuSoft
”Boost
