ObjectARX
Saving selected entities as bitmap
1 REPLY 1
472 Views, 1 Reply
I want to save the selected entities as a bitmap image (32x32 pixel) in AutoCAD. When I use "Export" functionality, the bitmap is created, but it is the same size as the AutoCAD's screen and added the selected entity only.
I want an image which is cropped to the selected entities only.
Santosh
1 REPLY 1
owenwengerd
Before exporting , you can change the document window size so it has the desired height-to-width ratio, then zoom the view so your target entities fill the screen.
Owen Wengerd
ManuSoft
”Boost
