I got this Error upon return the following code. Anyone can tell me why and how to fix it please ? Thanks in advance
AcDbLayerTable* pLayerTbl = NULL;
acdbCurDwg()->getSymbolTable(pLayerTbl,AcDb::kForWrite);
AcDbLayerTableRecord* pBTR = new AcDbLayerTableRecord();
AcCmColor color;
int index;
acedInitGet(RSG_NONULL && RSG_NOZERO && RSG_NONEG, NULL);
acedGetInt(_T("\n Input layer color "), &index);
color.setColorIndex(index);
pBTR->setColor(color);
pBTR->close();
ACHAR name;
acedGetString(0,_T("\n Input layer name "), &name);
pBTR->setName(&name);
pLayerTbl->add(pBTR);
pBTR->close();
pLayerTbl->close();
Solved by owenwengerd. Go to Solution.
The 'name' buffer needs to have enough space to hold the entered string.
Owen Wengerd
ManuSoft
But there is not command like name.buffer nor name->buffer. How can i set the buffer long enough to solve this? Beside, this still crash even if the name i entered is 1 character long
The only one-character string is the empty string, because all C strings are null terminated.
To allocate name on the stack with a fixed size:
ACHAR name[134];
Owen Wengerd
ManuSoft
It is still not working thought :(. I have changed my code like you said, but the problem remain
My current code (the rest is unchanged š
ACHAR name[100];
acedGetString(0,_T("\n Input layer name "), &name[100]);
pBTR->setName(&name[100]);
You're sending a pointer to the last character in the allocated buffer, which makes it effectively a one-character buffer. Use all of the buffer, starting from the beginning (and note that a 100 character buffer is not large enough -- it must be at least 134):
ACHAR name[134];
acedGetString(0,_T("\n Input layer name "), name);
//need to check return value in case there was an error
pBTR->setName(name);
Owen Wengerd
ManuSoft
I came over this topic searching for a problem. And I noticed that you are first closing pBTR, then trying to change it! You should remove the first pBTR->close(); I think
