ObjectARX
revolve trouble with objectarx 2015
6 REPLIES 6
ynapeu
599 Views, 6 Replies
Hello
i have trouble with the AcDb3dSolid revolve function.
The following code works fine in Autocad2012,2013,2014.
Now in 2015 i get an Acad::eOk, but the Solid has no volume.
if i use the createRevolvedSolid function
    AcDbRevolveOptions arevopt;
    es=m_solid->createRevolvedSolid((AcDbRegion*)l_region[0],axisPoint,axisDir,angleOfRevolution,0,arevopt);
i get the correct solid.
Is there a know error in the revolve funtion?
void testsolid_rotate()
 bool bret=false;
 AcGePoint3d axisPoint(0.0,0.0,0.0);
 AcGeVector3d axisDir(0.0,1.0,0.0);
 AcDbVoidPtrArray l_ar,l_region;
 AcDbLine *aline=new AcDbLine();
 aline->setStartPoint(AcGePoint3d(5.0,0.0,0.0));
 aline->setEndPoint(AcGePoint3d(10.0,0.0,0.0));
 l_ar.append(aline);
 aline->setStartPoint(AcGePoint3d(10.0,00.0,0.0));
 aline->setEndPoint(AcGePoint3d(10.0,20.0,0.0));
 l_ar.append(aline);
 aline->setStartPoint(AcGePoint3d(10.0,20.0,0.0));
 aline->setEndPoint(AcGePoint3d(8.0,20.0,0.0));
 l_ar.append(aline);
 aline->setStartPoint(AcGePoint3d(8.0,20.0,0.0));
 aline->setEndPoint(AcGePoint3d(8.0,40.0,0.0));
 l_ar.append(aline);
 aline->setStartPoint(AcGePoint3d(8.0,40.0,0.0));
 aline->setEndPoint(AcGePoint3d(5.0,40.0,0.0));
 l_ar.append(aline);
 aline->setStartPoint(AcGePoint3d(5.0,40.0,0.0));
 aline->setEndPoint(AcGePoint3d(5.0,0.0,0.0));
 l_ar.append(aline);
 AcDbRegion::createFromCurves(l_ar,l_region);
 AcDb3dSolid *m_solid;
        m_solid=new AcDb3dSolid();
 if (m_solid)
  m_solid->setRecordHistory(false);
  m_solid->setDatabaseDefaults(acdbHostApplicationServices()->workingDatabase());
  double angleOfRevolution = 2.0*M_PI;
  if (m_solid->revolve((AcDbRegion*)l_region[0],axisPoint,axisDir,angleOfRevolution)==Acad::eOk)
   Acad::ErrorStatus es;
   double volume;
    AcGePoint3d centroid;
   double momInertia[3];
   double prodInertia[3];
   double prinMoments[3];
   AcGeVector3d prinAxes[3];
   double radiiGyration[3];
   AcDbExtents extents;
   m_solid->getMassProp(volume,centroid,momInertia,prodInertia,prinMoments,prinAxes,radiiGyration,extents);
   ads_printf(_T("\n Volume1:%g"),volume);
6 REPLIES 6
owenwengerd
in reply to: ynapeu
Is workingDatabase() returning a non-NULL value? What is the return value of the call to getMassProp()?
Owen Wengerd
ManuSoft
ynapeu
in reply to: owenwengerd
workingDatabase() returning a value.
getMassProp() returns a Acad::eOk.
returns Acad::eOk no Solid.
Volume=0;
i get the solid.
Volume is okay.
owenwengerd
in reply to: ynapeu
Sorry, I'm out of ideas. I recommend to attach a complete self-contained buildable function for reproducing the problem so that someone from Autodesk can try to reproduce it.
Owen Wengerd
ManuSoft
ynapeu
Hi Owen,
thanks.
In the first post is the fully code.
Copy it and you can try it.
Maybe somebody at autodesk can debug the revolve function and find the error.
owenwengerd
in reply to: ynapeu
I am able to reproduce the problem. I've cleaned up your code and made a more readable test case:
//region boundary curves
AcDbLine Line1(AcGePoint3d(5.0,0.0,0.0), AcGePoint3d(10.0,0.0,0.0));
AcDbLine Line2(AcGePoint3d(10.0,0.0,0.0), AcGePoint3d(10.0,20.0,0.0));
AcDbLine Line3(AcGePoint3d(10.0,20.0,0.0), AcGePoint3d(8.0,20.0,0.0));
AcDbLine Line4(AcGePoint3d(8.0,20.0,0.0), AcGePoint3d(8.0,40.0,0.0));
AcDbLine Line5(AcGePoint3d(8.0,40.0,0.0), AcGePoint3d(5.0,40.0,0.0));
AcDbLine Line6(AcGePoint3d(5.0,40.0,0.0), AcGePoint3d(5.0,0.0,0.0));
AcDbVoidPtrArray rCurves;
rCurves.append(&Line1);
rCurves.append(&Line2);
rCurves.append(&Line3);
rCurves.append(&Line4);
rCurves.append(&Line5);
rCurves.append(&Line6);
AcDbVoidPtrArray rRegions;
Acad::ErrorStatus es = AcDbRegion::createFromCurves(rCurves, rRegions);
if (es == Acad::eOk && !rRegions.isEmpty())
	AcDb3dSolid Solid;
	Solid.setRecordHistory(false);
	Solid.setDatabaseDefaults(acdbHostApplicationServices()->workingDatabase());
	double angleOfRevolution = 2.0 * 3.141592653589793238462643383279502884197;
	es = Solid.revolve((AcDbRegion*)rRegions[0], AcGePoint3d::kOrigin, AcGeVector3d::kYAxis, angleOfRevolution);
	if (es == Acad::eOk)
		double volume = 0;
		es = Solid.getMassProp(volume, centroid, momInertia, prodInertia, prinMoments, prinAxes, radiiGyration, extents);
Owen Wengerd
ManuSoft
moogalm
in reply to: ynapeu
Hi , This is a known issue ,we have already raised a request with our development team. Yes ,that is the workaround I planned to post ,anyway you got it and thanks for sharing with us 🙂
”Boost
