Reset DBMOD
Reset DBMOD
Message 1 of 8
Reset DBMOD
According to the documentation DBMOD is read-only, however, I would like to
be able to perform and operation other than save to reset this property to
0. Is this possible w/ Arx 2000?
Martin Schmid, EIT, CCSA, MCDBA, MCSE
Replies (7)
Message 2 of 8
AcApDocument::pushDbmod() and
AcApDocument::popDbmod()
AcadXTabs: Document Tabs for AutoCAD
http://www.acadxtabs.com
"Martin Schmid" wrote in message
news:18C6079C92D13C9C8693586FE48B75D4@in.WebX.maYIadrTaRb...
> Thanks,
Message 3 of 8
On Thu, 4 Sep 2003 07:26:13 -0700, "Martin Schmid"
There are 2 functions in AutoLISP that allow you to save and restore the
state of DBMOD. They are (acad-push-dbmod) and (acad-pop-dbmod). You
may have to se if there is a similar function that can be used in your
application.
Message 4 of 8
I don't follow... if the dbmod variable is already a value other than 0, and
I push that variable (ie, the documentation states that I can't pop 'til I
push, and trying to results in 'eIllegalReplacement'), any subsequent
change, other than a save, will result in dbmod still being !=0.
"Tony Tanzillo" wrote in message
news:B4FC33B95E281090CD0E0F1812ACBF00@in.WebX.maYIadrTaRb...
to
to
> > Thanks,
Message 5 of 8
Do you mean you want to change DBMOD to 0 and leave it that way?
In that case, you can use this undocumented export:
extern long acdbSetDbmod(class AcDbDatabase* pDb, long newVal);
news:84C173FAFCBA99534046626F90712ACA@in.WebX.maYIadrTaRb...
> Thanks,
> to
> to
> > > Thanks,
Message 6 of 8
Yup... That appears to be what I need. The problem is that the (idiots)
that setup our office's cad system as a 'feature' that dumps in all the
standard linetypes and sets various variables when a drawing is open (in the
MNL or some file.. haven't tracked it down yet). This is annoying, and
poses a problem when using pack and go (i.e., you must save first.. etc).
However, I have come up with another work around, but it always nice to know
about undocumented functions!
news:22E44B538C2C5C81E2D04D2F7C23C7BF@in.WebX.maYIadrTaRb...
and
I
> > Thanks,
like
> > to
property
> > to
> > > > Thanks,
Message 7 of 8
I'm not sure I understand. That is what the previous two
functions I mentioned are for (pushdbMod and popDbmod).
You call pushDbmod() before you change anything, and then
call popDbmod() after you're done.
news:6214FE21756A625B0435E946BB5B8537@in.WebX.maYIadrTaRb...
> Thanks,
> and
> I
> > > Thanks,
> like
> > > to
> property
> > > to
> > > > > Thanks,
Message 8 of 8
Yes.. however for my purpose acdbSetDbmod is better.
pushDbMod / popDbMod assumes that 'you' are making or have control over the
changes between the push/pop, which in my case, I don't.
From the documentation "NOTE In order to avoid overwriting DBMOD flags set
by other applications, try to avoid having a DBMOD value pushed when your
code loading an application is doing anything which might cause another
application to be loaded, including loading of DWG or DXF files, acedCmd()
invocation of application-defined commands, and direct loading of
applications"
I can't ensure that I won't cause the case in the NOTE.
news:8A6B354E30694826394E250ED53D4E1D@in.WebX.maYIadrTaRb...
the
etc).
know
> > Thanks,
than 0,
> > and
'til
> > I
subsequent
> > > > Thanks,
message
would
> > like
> > > > to
> > property
> > > > to
> > > > > > Thanks,
