ObjectARX
RealDWG 2011 Icon Files - Missing DXF.ico FILE
3 REPLIES 3
darrell.ross
1279 Views, 3 Replies
I have been setting up the installer for our app which uses the provided files from RealDWG 2011.
I was linking the icon files when I noticed that the included icon files in the Redistrib folder are:
 dwg.ico
 dwf.ico
The "RealDWG Logo and AutoCAD DWG Icon Use" portion of the help files state:
"If not already registered, the application using RealDWG must register with the file system the Autodesk DWG and DXF icons."
But there is no dxf.ico file provided. I think this is a mistake on Autodesk's part. They probably meant to include the dxf.ico file.
Fortunately for me, I have an older version (RealDWG 2008) and it has the correct icon file for dxf. Is this fact already noted somewhere? If so, are there other known issues for which I can acquire updates? Where?
3 REPLIES 3
artc2
in reply to: darrell.ross
You are right this was a mistake.  It will be fixed in the next release.
I can email you the dxf.ico file for RealDWG 2011 if you want it.
We don't do updates for the RealDWG SDK.
darrell.ross
in reply to: artc2
I am using the RealDWG 2008 dxf.ico file at the moment. Is it the same as the 2011 one? If it is not, then I should probably get the 2011 one. Thanks!
artc2
The 2008 and 2011 icons are quite different.  if you send me an email (artc@autodesk.com) I'll reply with the icon attached.
”Boost
