ObjectARX
read a SHX file to acad
2 REPLIES 2
majklha
1476 Views, 2 Replies
How to read shx file (file with shapes definition) to acad, using C++ (I can it do with acedCommand).
I need it for linetypes.. In acad you can do by command _load.
2 REPLIES 2
in reply to: majklha
I believe that the only way to load an shx is via
acedCommand().
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
How
with acedCommand). I need it for linetypes.. In acad you can do by command
_load. Thanks
AlexanderRivilis
Note that this code was written before "Unicode revolution" in AutoCAD and you have to support unicode.
{code}
static void CreateMyLineType(void)
Acad::ErrorStatus es;
// Finding AcDbTextStyleTableRecord for ltypeshp.shx.
// This file must be in support path's of AutoCAD
AcDbTextStyleTablePointer pTT(acdbCurDwg(),AcDb::kForRead);
if (pTT.openStatus() == Acad::eOk) {
AcDbObjectId ttId;
AcDbTextStyleTableIterator *iter = NULL;
if ((es = pTT->newIterator(iter)) != Acad::eOk) {
acutPrintf("\npTT->newIterator(iter)=%s",acadErrorStatusText(es));
return;
for (iter->start();!iter->done(); iter->step()) {
AcDbTextStyleTableRecord *pTTR=NULL;
if ((es = iter->getRecord(pTTR,AcDb::kForRead)) != Acad::eOk) {
acutPrintf("\niter->getRecord(pTTR,AcDb::kForRead)=%s",acadErrorStatusText(es));
delete iter;
return;
const char *fname = NULL;
pTTR->fileName(fname);
if (!stricmp(fname,"ltypeshp.shx")) {
ttId = pTTR->objectId();
pTTR->close();
break;
pTTR->close();
delete iter;
// If there is no AcDbTextStyleTableRecord for ltypeshp.shx - creating it.
if (ttId.isNull()) {
if (pTT->upgradeOpen() != Acad::eOk) {
return;
AcDbTextStyleTableRecord *pTTR = new AcDbTextStyleTableRecord();
pTTR->setFileName("ltypeshp.shx");
pTTR->setIsShapeFile(true);
if ((es = pTT->add(ttId,pTTR)) != Acad::eOk) {
acutPrintf("\npTT->add(ttId,pTTR)=%s",acadErrorStatusText(es));
delete pTTR;
return;
pTTR->close();
pTT->close();
// Creating LineType
AcDbLinetypeTablePointer pLT(acdbCurDwg(),AcDb::kForRead);
if ((es = pLT.openStatus()) != Acad::eOk) {
acutPrintf("\npLT.openStatus()=%s",acadErrorStatusText(es));
return;
AcDbObjectId ltrid;
if (pLT->getAt("MY_LINETYPE",ltrid) == Acad::eOk) {
acutPrintf("\nMY_LINETYPE linetype is existing!");
return;
if ((es = pLT->upgradeOpen()) != Acad::eOk) {
acutPrintf("\npLT->upgradeOpen()=%s",acadErrorStatusText(es));
return;
AcDbLinetypeTableRecord *pLTR = new AcDbLinetypeTableRecord();
pLTR->setName("MY_LINETYPE");
pLTR->setComments("My own linetype");
pLTR->setPatternLength(36.83);
pLTR->setNumDashes(4);
pLTR->setDashLengthAt(0,6.35);
pLTR->setDashLengthAt(1,-2.54);
pLTR->setShapeNumberAt(1,133);
pLTR->setShapeStyleAt(1,ttId);
pLTR->setShapeOffsetAt(1,AcGeVector2d(-2.54,0));
pLTR->setShapeScaleAt(1,2.54);
pLTR->setDashLengthAt(2,-2.54);
pLTR->setDashLengthAt(3,25.4);
if ((es = pLT->add(ltrid,pLTR)) != Acad::eOk) {
acutPrintf("\npLT->add(ltrid,pLTR)=%s",acadErrorStatusText(es));
delete pLTR;
pLTR->close();
static void ShapeNames(void)
struct SHAPESTRUCT {
unsigned short iShapeNumber; // shape number
unsigned short iDefBytes; // number of data bytes in shape, 2000 max
unsigned char *lpszShapeName; // pointer to shapename
unsigned char *lpszSpecBytes; // pointer to shape specification bytes
char SHAPE10[] = "AutoCAD-86 shapes 1.0";
char SHAPE11[] = "AutoCAD-86 shapes 1.1";
resbuf *rbfile = NULL;
if (RTNORM == acedGetFileNavDialog("Select shape file","","shx","ShapeNames",0,&rbfile))
FILE *fshx = fopen(rbfile->resval.rstring,"rb"); acutRelRb(rbfile);
if (fshx) {
char desc[32];
fread (desc,sizeof(desc),1,fshx);
if (!strstr(desc,SHAPE10) && !strstr(desc,SHAPE11)) {
acutPrintf("\nIt is not shape file!");
fclose(fshx);
return;
fseek (fshx, (long)0x1c, SEEK_SET);
unsigned short iNumShapes = 0;
fread (&iNumShapes, sizeof (iNumShapes), 1, fshx);
SHAPESTRUCT *lpShapeList, *lpShape;
lpShapeList = (SHAPESTRUCT *)calloc(iNumShapes, sizeof (*lpShapeList));
for (int i=0; i < iNumShapes; i++) {
lpShape = lpShapeList + i;
fread(&(lpShape->iShapeNumber), sizeof (lpShape->iShapeNumber), 1, fshx);
fread(&(lpShape->iDefBytes), sizeof (lpShape->iDefBytes), 1, fshx);
if (lpShapeList->iShapeNumber != 0) { // Это файл формы
for (int i = 0; i < iNumShapes; i++) {
lpShape->lpszShapeName = (unsigned char *)(malloc (lpShape->iDefBytes));
fread (lpShape->lpszShapeName, sizeof (*lpShape->lpszShapeName), lpShape->iDefBytes, fshx);
acutPrintf("\nShape N%d = %s", i, lpShape->lpszShapeName);
free(lpShape->lpszShapeName);
} else {
free(lpShapeList);
fclose(fshx);
{code} Edited by: AlexanderRivilis on May 8, 2009 11:39 AM
”Boost
