Title: pSolid->setSubentColor(dbsubEntId,culo); has failed.in autocad
My source , in c++arx, work fine , the color has changed.
I try the command at line-command
Command: saveas…
or / and
Command: save…
The programe acad.exe have bug…
The “pSolid->close()” broken the acad.exe, please, you replace “????” with c++ source..
Please help. me…….
[source=cpp]
#include “brepapi.h”
//here ,open pAcDbObject in AcDb::kForRead
// here subentPath got value and okai…
rb=nil;
AcDbObjectId objId=pAcDbObject->objectId();
pAcDbObject->close(); // close pAcDbObject in mode=AcDb::kForRead
// Get the subentIds for the faces.
AcCmColor culo;
culo.setRGB(200,120,70u);
AcDb3dSolid* pSolid = NULL;
con_ercad = acdbOpenObject(pAcDbObject, objId, AcDb::kForWrite);
if (con_ercad != Acad::eOk) {
DEBUG_PRINT(_T("g403.error %d: Can't open entity. "), con_ercad);
return (rr);
pSolid = AcDb3dSolid::cast(pAcDbObject);
AcDbSubentId dbsubEntId = subentPath.subentId();
con_ercad=pSolid->setSubentColor(dbsubEntId,culo);
{ ads_retint(RTKWORD);
exitif(1,"g403.error rmv");
pSolid->close(); // ????????
ads_retint(RTNORM);
//ads_retint(subentPath.subentId().index());
return(AcRx::kRetOK);
[/source=cpp]
Regards……….
pAcDbObject and pSolid is the same object. That is why you are closing this object twice.
Try to delete (or comment) line:
pSolid->close();
Facebook | Twitter | LinkedIn
