ObjectARX
Problem with ObjectARX 2015
1 REPLY 1
nishant.bhayani
672 Views, 1 Reply
I am having problem calling the ObjectARX functions from VLIDE editor. Everything works fine from AutoCAD command prompt. here is the ObjectARX code snippet.
Registring the function
int (*func)() = setVariable;
acedDefun(_T("setVariable"),1);
acedRegFunc(func,1);
SetVariable Function
int setVariable()
  struct resbuf *rb = acutBuildList(5005,
  _T("Unicode String"), 5000);
  int resval = acedPutSym(_T("test"), rb);
  acutRelRb(rb);
  return 1;
If I call (setVariable) from AutoCAD command prompt its works fine, but while calling from VLIDE editor the AutoCAD becomes nonresponsive. I cannot do anything on AutoCAD but the VLIDE editor works fine. I cannot even close the VLIDE editor because the Exit menu option goes into disable mode.
the Same Arx woks fine in AutoCAD 2014 I am migrating ARX from 2014 to 2015 and I am stuck.
Please help me I have tried all possible options but not finding clue.
Thanks in advance.
Nishant
1 REPLY 1
moogalm
in reply to: nishant.bhayani
Hi Nishanth,
Please manually activate AutoCAD from VLISP->Window-> Activate AutoCAD.
Madhu.
”Boost
