Hi, If anyone knows when you import a recap point cloud into autocad 2015 you can trace, measure etc between points if you are in a command, if not, the point cloud is treated somewhat like a block. Thats perfect for a user, but I am unable to access it via .net, any Ideas?
Solved by Balaji_Ram. Go to Solution.
Point cloud API is at present only exposed using ObjectARX C++ API.
sorry, manipulating the point cloud entity using VB.Net is not possible.
Balaji
