I have written a function that creates AcDbMLeader and it produces perfect leaders. I just can' make the leader lines start on the right hand side of the mtext.
I have used the set functions in different combinations but nothing seems to work.
Does anyone have any ideas as to why this might be?
Many thanks
Hello Kenneth,
Have you tried using the "AcDbMLeader::setDoglegDirection" ?
This method turns the short line based on the direction vector provided to it.
If this does not help, can you please post a simple example to demonstrate the problem ?
Hi Balaji,
Thank you for the suggestion I will try that out and let you know if it fixes my problem.
I will attach my code if still I can't get it to work.
Thanks again,
Ken
