ObjectARX
ObjectARX Wizard 2012 on VS 2010
2 REPLIES 2
odoshi
924 Views, 2 Replies
I'm getting an error during the creation of a new C++ project in VS 2010 using the ARX Wizard 2012
--------------------------- Microsoft Visual Studio ---------------------------
Specified argument was out of the range of valid values.
Parameter name: value
--------------------------- OK   ---------------------------
Then the project is not built. Has anyone else seen this?
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
2 REPLIES 2
Virupaksha_aithal
in reply to: odoshi
Hi
Are you creating mixed managed project? If yes, then try below step
Edit the following file like below
C:\Program Files (x86)\Autodesk\ObjectARX Wizards for AutoCAD 2012\ArxAppWiz\Scripts\1033\default.js
Line #122
Change
config.ManagedExtensions =bDotNetModule ;
into
config.ManagedExtensions =(bDotNetModule == 'True') ;
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
odoshi
in reply to: Virupaksha_aithal
Yes, it was a mixed managed project. That fixed it.
Thank you!
Mike Caruso
”Boost
