where can I download ObjectARX for AutoCAD 2013?
Solved by Alexander.Rivilis. Go to Solution.
http://download.autodesk.com/esd/objectarx/2013/ObjectARX_2013_Win_64_and_32Bit.exe
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
I did not find the "Interop.ACSMCOMPONENTS19Lib.dll" reference.
where can I download "Interop.ACSMCOMPONENTS19Lib.dll"?
You have to create this file with next command:
tlbimp acsmcomponents19.tlb /out:Interop.ACSMCOMPONENTS19Lib.dll /namespace:AcSm /machine:x64
Explanation: https://adndevblog.typepad.com/autocad/2012/05/resolving-references-when-using-tlbimp-.html
Check this attached file.
tlbimp acsmcomponents19.tlb /out:Interop.ACSMCOMPONENTS19Lib.dll /namespace:AcSm /machine:x64Explanation: https://adndevblog.typepad.com/autocad/2012/05/resolving-references-when-using-tlbimp-.html
Do this work for Autocad 2020 and VISUAL BASIC 2019?
I need to recycle this 2013 code :
/* * SheetSetTools. © Andrey Bushman, 2013 * AutoCAD 2014 x64 Enu * * COMMANDS: * SS-RENUMBER-ALL - Update the numeration for all sheets in the all opened sheet sets: * numbering of each subgroup shall begin with 1. * * SS-RENUMBER-ALL-BASES-OF-FIRST - Update the numeration: to continue numbering on the * basis of the first element in the each subset (in the all opened sheet sets). * * AutoCAD references: * AcCoreMgd.dll * AcDbMgd.dll * AcMgd.dll * Interop.ACSMCOMPONENTS19Lib.dll */ using System; using cad = Autodesk.AutoCAD.ApplicationServices.Application; using App = Autodesk.AutoCAD.ApplicationServices; using Db = Autodesk.AutoCAD.DatabaseServices; using Ed = Autodesk.AutoCAD.EditorInput; using Rtm = Autodesk.AutoCAD.Runtime; using Comp = ACSMCOMPONENTS19Lib; [assembly: Rtm.ExtensionApplication(typeof(Bushman.AutoCAD.SheetSetTools.SheetSetCommands))] [assembly: Rtm.CommandClass(typeof(Bushman.AutoCAD.SheetSetTools.SheetSetCommands))] namespace Bushman.AutoCAD.SheetSetTools { public class SheetSetCommands : Rtm.IExtensionApplication { const String ns = "bush"; // namespace /// <summary> /// Update the numeration for all sheets in the all opened sheet sets: numbering of /// each subgroup shall begin with 1. /// </summary> [Rtm.CommandMethod(ns, "ss-renumber-all", Rtm.CommandFlags.Modal)] public void Renumber_All() { Renumber(); } /// <summary> /// Update the numeration: to continue numbering on the basis of the first element /// in the each subset (in the all opened sheet sets). /// </summary> [Rtm.CommandMethod(ns, "ss-renumber-all-bases-of-first", Rtm.CommandFlags.Modal)] public void Renumber_all_bases_of_first() { Renumber(true); } /// <summary> /// To update numbering of all sheets in the all opened sheet sets. /// </summary> /// <param name="continue_numbering">True - to continue numbering on the basis /// of the first element in the each subset (in the all opened sheet sets); /// False - Numbering of each subgroup shall begin with 1 (in the all opened /// sheet sets).</param> void Renumber(Boolean continue_numbering = false) { App.Document doc = cad.DocumentManager.MdiActiveDocument; Db.Database db = doc.Database; Ed.Editor ed = doc.Editor; Comp.AcSmSheetSetMgr mng = new Comp.AcSmSheetSetMgr(); Comp.IAcSmEnumDatabase enumerator = mng.GetDatabaseEnumerator(); enumerator.Reset(); Comp.AcSmDatabase smDb = null; while ((smDb = enumerator.Next()) != null) { smDb.LockDb(db); String fname = smDb.GetFileName(); Comp.AcSmSheetSet sheetset = smDb.GetSheetSet(); String name = sheetset.GetName(); String descr = sheetset.GetDesc(); ed.WriteMessage("\nSheet Set name: {0}\n", name); Int32 ren_count = 0; // count of renamed sheets. Comp.IAcSmEnumComponent encomp = sheetset.GetSheetEnumerator(); encomp.Reset(); Comp.IAcSmComponent component = null; while ((component = encomp.Next()) != null) { ProcessElement(ed, component, ref ren_count, continue_numbering); } encomp.Reset(); smDb.UnlockDb(db, true); ed.WriteMessage("Renumbered sheets count: {0}\n", ren_count); } enumerator.Reset(); } /// <summary> /// Recursive processing of the elements: change the sheet's number. /// </summary> /// <param name="ed">An Editor for the output.</param> /// <param name="component">Component of Sheet Set.</param> /// <param name="ren_count">The count of renumbered sheets in the sheet set.</param> /// <param name="continue_numbering">True - to continue numbering on the basis /// of the first element in the each subset (in the all opened sheet sets); /// False - Numbering of each subgroup shall begin with 1 (in the all opened /// sheet sets).</param> void ProcessElement(Ed.Editor ed, Comp.IAcSmComponent component, ref Int32 ren_count, Boolean continue_numbering) { Array array = null; component.GetDirectlyOwnedObjects(out array); if (array != null) { Int32 sheet_number = 1; Boolean basis_of_first = continue_numbering; foreach (var item in array) { if (item is Comp.IAcSmSubset) { ProcessElement(ed, (Comp.IAcSmSubset)item, ref ren_count, continue_numbering); } else if (item is Comp.IAcSmSheet) { Comp.IAcSmSheet sheet = (Comp.IAcSmSheet)item; String cur_str_value = sheet.GetNumber(); Int32 int_value = 0; Boolean is_int32 = Int32.TryParse(cur_str_value, out int_value); if (!is_int32 || (!basis_of_first && int_value != sheet_number)) { sheet.SetNumber(sheet_number.ToString()); ++ren_count; } else if (basis_of_first) { sheet_number = int_value; } ++sheet_number; basis_of_first = false; } else if (item is Comp.IAcSmPersist) { Comp.IAcSmPersist persist = (Comp.IAcSmPersist)item; } else { ed.WriteMessage("Unknown object: {0}", item.GetType().ToString()); } } } } #region IExtensionApplication Members public void Initialize() { App.Document doc = cad.DocumentManager.MdiActiveDocument; Ed.Editor ed = doc.Editor; ed.WriteMessage("\nSheetSetTools. © Andrey Bushman, 2013\n\n"); } public void Terminate() { // Empty body. } #endregion } }
No. You need ObjectARX SDK 2020 and ACSMCOMPONENTS23.tlb
See attached file.
P.S.: This forum only for ObjectARX (native C++). Ask this question in .NET forum: https://forums.autodesk.com/t5/net/bd-p/152
for AutoCAD 2020 should I use this code?
tlbimp acsmcomponents23.tlb /out:Interop.ACSMCOMPONENTS23Lib.dll /namespace:AcSm /machine:x64
Yes. But I've attached above ready for use file: https://forums.autodesk.com/autodesk/attachments/autodesk/34/38519/1/Interop.ACSMCOMPONENTS23Lib.zip
I tried use convert an update version using Visual Basic, but not luck:
tlbimp "C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64\acsmcomponents24.tlb" /out:Interop.ACSMCOMPONENTS24Lib.dll /namespace:AcSm /machine:x64
could help me or teach me how should I do this?
here my error message:
C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64>tlbimp "C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64\acsmcomponents24.tlb" /out:Interop.ACSMCOMPONENTS24Lib.dll /namespace:AcSm /machine:x64
Microsoft (R) .NET Framework Type Library to Assembly Converter 4.8.3928.0
Copyright (C) Microsoft Corporation. All rights reserved.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmFiler.ReadRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmFiler.ReadBytes' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmPersistProxy.GetRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmDSTFilerClass.ReadRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmDSTFilerClass.ReadBytes' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmPersistProxyClass.GetRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : Type library imported to C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64\Interop.ACSMCOMPONENTS24Lib.dll
C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64>tlbimp "C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64\acsmcomponents24.tlb" /out:Interop.ACSMCOMPONENTS24Lib.dll /namespace:AcSm /machine:x64 Microsoft (R) .NET Framework Type Library to Assembly Converter 4.8.3928.0 Copyright (C) Microsoft Corporation. All rights reserved. TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmFiler.ReadRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate. TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmFiler.ReadBytes' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate. TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmPersistProxy.GetRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate. TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmDSTFilerClass.ReadRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate. TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmDSTFilerClass.ReadBytes' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate. TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmPersistProxyClass.GetRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate. TlbImp : Type library imported to C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64\Interop.ACSMCOMPONENTS24Lib.dll
There are only warnings - Interop.ACSMCOMPONENTS24Lib.dll was produced. So you can use it.
https://forums.autodesk.com/t5/net/update-2013-references-to-2022/td-p/10963984
In this post I tried both references, the dll(after use the command) and the TLD source. With both still did not work.
Until remember, in the code in the link exist a duplicate attribute error, and was solved when I used the version 23 reference posted above
Do will is reference not solve the duplicate attribute error?
Are you talking about this error: "Error CS0579 Duplicate 'Rtm.ExtensionApplication' attribute..." ?
This error not linked with reference of this dll-file. Check all source cs-files in your project...
