ObjectARX
ObjectARX
Valued Contributor
3 Kudos
Post 1 of 4
ObjectArx / Dbx crashes in debug build.
229 Views, 3 Replies
11-20-2012 10:32 AM
I have just started a project, a single arx dll and a single dbx dll. Both only implement an application class, no commands, no custom entities, no dialogs etc... When I attempt to load the dbx and arx applications in debug build, I get a crash:
Unhandled exception at 0x000007fefd5acaed (KernelBase.dll) in acad.exe: 0x804F4C45: 0x804f4c45.
Visual Studio 2010
ObjectArx 2012
AutoCAD 2012 (64 bit)
Any hints. Note, as stated above, there is nothing in these projects other than the application classes providing the entry points.
I have attached a zip containing the projects. In each contains a single class that I have created. InFormArxApp and InFormDbxApp.
Mike
Valued Contributor
3 Kudos
Post 2 of 4
Re: ObjectArx / Dbx crashes in debug build.
11-20-2012 11:12 AM in reply to: mbujak
Further, if I only load the arx or dbx application alone, the crash does not occur. If I load the both the DBX and the ARX the crash occures.
Mike
Distinguished Mentor
100 Kudos
Post 3 of 4
11-20-2012 12:15 PM in reply to: mbujak
You should show the line(s) of code where the exception occurs, and what the problem is at that point that caused the exception.
Owen Wengerd
ManuSoft
Valued Contributor
3 Kudos
Post 4 of 4
11-23-2012 08:27 AM in reply to: owenwengerd
Well I was hoping to get this resolved but the crashing has seemed to resolve itself. I haven't changed anything in that code so I am not sure what the problem is/was.
Mike
