Can anyone explain why the userdata.lib is not included with the ObjectARX 2013 download? And how do you get that file based on the following link:
http://forums.autodesk.com/t5/Autodesk-ObjectARX/Object-Arx-2013-Linking-problem/td-p/3531668
I get this error during link and can't find how to get this file anywhere.
Thanks.
Solved by StephenPreston. Go to Solution.
It sounds like it's just an export library, so why not just create it yourself?
Hi bobje,
I just posted the missing libs here for you - http://adndevblog.typepad.com/autocad/2012/10/userdatalib-files-for-objectarx-2013-sdk.html. Sorry for the inconvenience.
