ObjectARX
ObjectArx 2010 Menu Bar - MFC
1 REPLY 1
1596 Views, 1 Reply
Hello All!
I am using a class from ObjectARx 2010 sample kit(AsdkMfcComSamp_dg) code called CAcadPopupMenus to add a pop menu to the menu bar. This class is great and gives me the functionality I need but I am wondering about two things:
1.How can I disable menu items?
2.How can I hide(not remove) menu items?
One more way I tried adding a menu is by using class AdMenuBar. This was also unsuccessful:
AdApplicationFrame* pApplication = acedGetApplicationFrame();
AdMenuBar* pACMenuBar = pApplication->GetMenuBar();
HMENU hMenuBar = pACMenuBar->GetMenuHandle();
CMenu* pMfcMenu = new CMenu;
pMfcMenu->Attach(hMenuBar);
pMfcMenu->CreatePopupMenu();
pMfcMenu->AppendMenu(MF_STRING | MF_ENABLED | MF_BYCOMMAND, IDM_SOLIDACM_START, solidcam_start_menu);
pMfcMenu->AppendMenu(MF_STRING | MF_GRAYED | MF_BYCOMMAND, IDM_SOLIDACM_END , solidcam_end_menu );
pMfcMenu->AppendMenu(MF_POPUP, (UINT) (HMENU) *pMfcMenu, solidcam_menu);
pACMenuBar->UpdateMenu();
This is one way I tried which did not work out. Should I use AdMenuBar->AddMenuItem? I tried but it also unsuccsessful. Maybe I am doing something wrong:
MENUITEMINFO MenuItemInfo;
pACMenuBar->AddMenuItem(pMfcMenu->GetSafeHmenu(), //HMENU hMenu);
5, //UINT nPos - Random
MenuItemInfo, //const MENUITEMINFO& menuItem Empty - Problem?
NULL, // LPFNADMENUCALLBACK pfnCallback - Not sure what to put here
_T("Menu Test") //const wchar_t *wszHelpString - For Doc??
AddMenuItem returns 0. I am pretty sure I am doing something wrong but I am not sure...
Any help would be extremely appreciated!
Thanks!
David Somekh
Software Engineer
david.somekh@solidcam.com
1 REPLY 1
Hi, eran!
e> I am using a class from ObjectARx 2010 sample kit(AsdkMfcComSamp_dg) code
e> called CAcadPopupMenus to add a pop menu to the menu bar. This class is
e> great and gives me the functionality I need but I am wondering about two
e> things:
e> 1.How can I disable menu items?
You can use PopupMenuItem.Enable(FALSE) method.
Look at AutoCAD 2010 Help->Developer Help->ActiveX and VBA Reference->Objects->PopupMenuItem object
Enable property example
e> 2.How can I hide(not remove) menu items?
As I know it is impossible hide menu item without removing it.
Best Regards,
Alexander Rivilis.
”Boost
