I'm trying to use an MFC example to get a print preview window to open up in AutoCAD, and I can't get the window to display. In the past I have made a couple of applications that show a dialog, but this one is based on a sample that uses a frame window first, and I haven't found any ObjectARX examples that are similar. I know very little about MFC so I started with example code (https://workspaces.codeproject.com/richard-stringer/printing-class-library) that works as a regular windows application and stripped it down and tried to integrate it into an ObjectARX project. Could someone please take a look at the attached project and point me in the right direction? Feel free to beat up on it. I'm sure there is plenty to pick on.
I'm using:
VS 2012
AutoCAD 2014 SP1
Windows 8 64 bit
Ralph
