ObjectARX
Mechanical 2014: ObjectId to AcDbObjectId from .NET to objectARX Through Wrapper
0 REPLIES 0
Message 1 of 1
SCTINFORMATICA
567 Views, 0 Replies
Hi Community,
I developed an application for Mechanical 2014. This app does something in .NET (c#) and the I need to reuse an old procedure in ObjectArx and the procedure works fine in mechanical 2013.
The problem is that I need to know the AcDbObjectId id.
.NET
ObjectId[] idArray;
//populate and iterate
btacmwrap.Class1 cl = new btacmwrap.Class1();
cl.partparS("key", "value", idArray[i].OldId.ToString());
Wrap DLL
void partparS(String ^a,String ^b, String ^c)
            wrss uj;
            CString s;
            //call ObjectArx function
            uj.partparS(CString(a),CString(b), CString(c));
ObjectARX
void setPartDataS(CString a,CString b, CString c)
    try
        long id;
        Adesk::IntPtr puntatore(_wtoi(c));
        AcDbObjectId refArray2 = refArray2.setFromOldId(puntatore);
        if( !refArray2.isValid())
         acutPrintf(_T("\nId not valid\n"));
         return;
        if (refArray2.isNull())
            acutPrintf(_T("\nId NULL\n"));
            return;
        if (refArray2.isErased())
            acutPrintf(_T("\nId erased\n"));
            return;
        Adesk::UInt32 numIt;
        CMapStringToString valueMap;
        Acad::ErrorStatus es ;
      int tmpNumIt;
      CString prompt, tmp;
      CMapStringToString newValueMap;
      newValueMap.SetAt(a,b);
      es = acmBomMgr->setPartData(refArray2,newValueMap);
      if( Acad::eOk != es ) {
        acutPrintf(_T("\nError returned for set part data (%d).\n"),es);
        return;
    catch(...)
        MessageBox(NULL,L"Eccezione in setParData",L"setParData",MB_ICONERROR);
Result: The ID is not valid.
and if I try to pass   idArray[i].OldIdPtr.ToInt64()  in .NET, the setPartData(...) in ObjectArx doesn't work and return eInvalidInput.
I also try to pass HANDLE but there's no way and I don't know where is the bug.
Please, help me.
Thank you,
Mario
SCT Informatica
0 REPLIES 0
”Boost
